Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
« Terug naar alle verhalen
A1150 fan was dead.
rmcpherson05 -
MacBook Pro 15" Core Duo Model A1150
MacBook Pro 15" Core Duo Model A1150 Right Fan Replacement
30 minuten - 2 uren
Moderate
Mijn probleem
My right fan was dead, never showed as running when I checked istat pro. Led to my mac running hotter than it should. Figured I would replace both since I already had to open it for the one.
Mijn oplossing
The only complaint was UPS delivered my fans a day late when I paid for next day air. The only difficult part was the small cable going across (and attached to) the left fan. (I forget the step #) Guide was thorough and VERY helpful.
Mijn advies
Kapton tape! The electrical tape covering the fans and vent ports were very sticky and did not want to attach to the new fans. I covered the old tape with Kapton. Also, the steps that require you to remove cables taped down the mother board need to be replaced as well.
MacBook Pro 15" (Model A1150) Left Fan Afbeelding
$29.99
MacBook Pro 15" (Model A1150) Right Fan Afbeelding
$29.99
0 Opmerkingen
Voeg opmerking toe
