Mijn probleem
The home button only worked about every 3-4 time i pressed it. Poor design to put a switch that wears out before the rest of the phone!
Mijn oplossing
The procedure to replace it is very involved, and i probably wouldn't do it again, but it did work, and my phone is running great now. The iFixit video was very helpful, but i think a step-by step PDF would have been better as you end up rewinding the video over and over to make sure you got it right.
Mijn advies
The guide has you remove the larger screws with washers to remove the display, but i think you could just loosen the ones that dont go through eyelets.
0 opmerkingen
