Ga door naar hoofdinhoud
« Terug naar alle verhalen
iMac 27" 2011 SSD failcon
tcrouse06 -
Mijn probleem
I thought it would be a good idea to open up my iMac and found out it wasn't going to be easy with no mounting hardware where it was supposed to be.
Mijn oplossing
The nice folks at foxcon either forgot to put in the mounting hardware for the ssd or Apple decided not to give you the option to put your own in. Opened it up and was disappointed. Put it all back together then my iMac would shut of every 20 or so minutes and that's when I realized I missed the connector for the Optical drive fan.
Mijn advies
I would help to do more research than I did. Although my iMac was supposed to be the only model that came with the hardware for a SSD, there was none to be found.
Metal Spudger Set afbeelding
Metal Spudger Set
$7.99
Heavy-Duty Suction Cups (Pair) afbeelding
$14.99
Mako Driver Kit - 64 Precision Bits afbeelding
$29.99
0 Opmerkingen
Voeg opmerking toe
