Works like a new
hardijs -
Mijn probleem
The late-2008 Macbook Pro 15" - after a lightning discharged quite nearby the screen acquired a bad habit of turning white washed out. Could be a coincidence or just a factor promoting a defect.
The washout could be remedied by a little pinching of the screen - so it was just a matter of time the glass broke :(
Mijn oplossing
After almost a 3 year daily usage - the glue has detoriated and the glass came off easily.
just get the right tools - nothing sharp and metalic.
Mijn advies
2 things to bear in ming - more so be prepared beforehand:
• clean the old glue thoroughly. it helps afterwards when the new glass/glue needs sticking to. I did use dimethilaether - definitely nothing petrol based - they do tend to dissolve the rubber band around the screen as well do dry a long time.
• remove all shipping/handling materials from the glass - it's easy to overlook the inside of the screen ;)
0 Opmerkingen
