Ga door naar hoofdinhoud
« Terug naar alle verhalen
2nd repair, 2nd success
bh -
MacBook Pro 15" Retina Display Mid 2015
Afbeelding van het verhaal
MacBook Pro 15" Retina Display Mid 2015 Battery Replacement
50 minuten
Difficult
Mijn probleem
I have two 2015 15" MBPs, one for work and one for home. Both of their batteries started bulging within a few months of each other.
Mijn oplossing
The guide was great, although I took the shortcut advice and only did the battery without removing speakers, etc. It was a little challenging, but after I did the first one the second one went much faster.
Mijn advies
Definitely cut the tip of the adhesive remover very small. You can slide the edge of the card under the battery, then drip the adhesive remover onto the card and that spreads it evenly under the battery. And be gentle.
MacBook Pro 15" Retina (Mid 2015) Battery Afbeelding
$109.99
0 Opmerkingen
Voeg opmerking toe
