Ga door naar hoofdinhoud
« Terug naar alle verhalen
Joycon Drift Repair
Gwen Sanchez -
Joy-Con
Afbeelding van het verhaal
Left Joy-Con Joystick Replacement
30 minuten
Moderate
Mijn probleem
My left joycon was experiencing really bad controller drift. It started off very minor but eventually it became so bad that I avoided playing certain games until it was fixed.
Mijn oplossing
The repair went well! I followed the guide available on ifixit and it was easy to follow. Took about half an hour to replace the joystick.
Mijn advies
Remember to calibrate your joycon after the repair is done!
Nintendo Switch Joy-Con/Switch Lite Joystick Afbeelding
$14.99
1 Opmerking
Waste of money/warranty - all you need to do is to tilt the joystick and give it a squirt of WD40 Contact Cleaner, rotate it a bit and calibrate if needed. No dissassembly or parts needed other than that can.
Peter Jensen - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 822
