Mijn probleem
My phone was slow and my battery started dying 5 times a day or more.
Mijn oplossing
My phone is working great now! The repair went pretty well, just took longer than I thought it would and the tiny screws were a challenge. The video was excellent as were the step-by-step instructions. The screws were challenging to get out and put back in. I felt I had to press down on the screwdriver to get them out, but even then it took several tries for each screw. The kit screwdriver was magnetic which is great for the tiny screws, but it still seemed like they needed to have just the right touch or be lined up correctly to come out and go back in. I did fail to read the part about the screws being different sizes and about it being potentially bad for your phone if a too long screw went where the short one should go. This was so that a screw that was too long didn’t poke against an important part of the phone. We ended up fine, but, I would recommend that you label a piece of white paper with the parts as you take them out.
Mijn advies
Read the step by step instructions and watch the video for tips on problems you may encounter.
0 opmerkingen
