Ga door naar hoofdinhoud
« Terug naar alle verhalen
First time user
Dennis Keith -
iPhone 5s
Afbeelding van het verhaal
How to replace the battery in your iPhone 5s
40 minuten
Moderate
Mijn probleem
I needed to Charge the phone about noon or 1 o’clock every day and then again at five or six
Mijn oplossing
The video was helpful to get an orientation and then I went to the step-by-step process. The only issue I had was removal of the tape holding the battery in place one of them came out easily the other one broke off and it took some work to get it out.
Mijn advies
Based on my experience I would say there are two things to be careful about one is to be sure you have a clean workspace where the little screws can’t get blown around or lost. Also do not twist the tape when you pull it out and when you need to work it around the battery be very careful and use some soft edged tools to help you get it around the corners.
iPhone 5s Battery Afbeelding
iPhone 5s Battery
$29.99
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 66
