Replaced Battery on Macbook Air 13" (Mid 2013)
Mijn probleem
Old Battery was losing power too quickly (2 hours).
Mijn oplossing
The guide has some good info on how to remove the battery. I did have some issues securing the battery with the screws. The two 2.4 mm T5 Torx screws were difficult to line up. I started the
Three 6.3 mm T5 Torx screws just slightly to secure the battery to the case and then had to shift the battery a bit to get the smaller screws lined up and secure.
Mijn advies
I purchased the replacement battery from We Love Macs and it actually came with the tools required for the repair. I wish I knew that before I bought both tools through iFixit, would have saved me $25 on a $200 repair job.
Also, the New battery came with plastic protection sheets on the 4 cells, which I wasn't sure if I should remove. There was a warning sticker that indicated that removing the sheets voids the warranty but I removed a sheet anyway before I thought better of it and replaced it. I secured the battery, replaced the cover and started up my mac and it started up right away. I guess it should've have been obvious but would have been nice if there was some information on the guide that the battery might come with these.
0 opmerkingen
