Ga door naar hoofdinhoud
« Terug naar alle verhalen
EASY AS 1.. 2... 3 !! Thank you
Steven Coffey -
iPhone 6
Afbeelding van het verhaal
iPhone 6 Battery Replacement
30 minuten
Moderate
Mijn probleem
My device's response time was diminishing.
Mijn oplossing
Easy as 1.. 2.. 3 !
Largest obstacles were adhesive strips employed to anchor battery to backplate.
Utilized hair dryer (heat) that made adhesive strips more pliable which resulted in a clean removal.
Secured display to box instead of fully removing it.
Mijn advies
Anchor display to packaging to avoid interaction with as many connections as possible.
Heat the back plate of the phone first to make adhesives more pliable.
Use of FLAT tip tweezers from medicine cabinet to manipulate adhesive from the underside of installed battery, keeping strip taught.
iPhone 6 Battery Afbeelding
iPhone 6 Battery
$29.99
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 110
