Ga door naar hoofdinhoud
« Terug naar alle verhalen
My First iPad Repair
Leif DeWolf -
iPad 4 CDMA
iPad 4 CDMA Lightning Connector Replacement
1 uur
Easy
Mijn probleem
It wasn't charging, the iPad would see the charger was plugged in, but no charge would go to the battery.
Mijn oplossing
It went well, i used the iFixit repair guide to make sure i was doing it correctly. Only issue i had was that i broke the home button cable and had to replace that as well, I didn't pull the pick out quite far enough on the side with the cable, but that was easy to fix as well.
Mijn advies
Be careful on the left side, i thought i had the pick far enough out but i still managed to snag the home button cable. Its always a bummer when you have to fix more parts than you needed to.
iPad 4 Lightning Connector Afbeelding
$19.99
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 32
