2012 MBP Retina 15" Battery Replacement
Mijn probleem
The system shows the battery is having a problem
Mijn oplossing
went well. Remember to drain your battery first just for better safety.
Mijn advies
you can follow the advice from here: https://www.youtube.com/watch?v=ruG2Nh-r..., i.e. use a string to "cut out" the battery from the container.
It worked pretty well and so you don't have to take everything apart because you don't need to use the adhesive liquid remover a lot.
0 opmerkingen
