Macbook Pro Mid 2009 Dual Drive Installation
Mijn probleem
I use a MacBook Pro mid-2009 as a second machine. The CD drive failed long ago, so I decided to use the slot for a second drive.
Mijn oplossing
The repair isn't terribly tricky, but it can be time consuming. The mounting screws need to be inserted into tight spaces.
Mijn advies
(1) If you are careful, there is no need to unplug the camera cable from its socket. That's a good strategy because the plastic stick-on strip that hold it into place would be hard to reinstall. (2) Once you pull the camera cable off the drive to be removed, it will not stick back on by itself. I bought some Tesa 41395 4mm tape, and that stuck it back onto the new drive perfectly. Be careful to position the camera cable so that it can't be cut by the edge of the new drive. (3) I used a tiny bit of scotch tape to hold the drive mounting screws onto the screwdriver, so that I could start them the first couple of turns.
0 opmerkingen
