Mijn probleem
Battery wasn’t holding it’s charge. Most times it’ll go from 50% down to empty and when charging it’ll jump up to 40%
Mijn oplossing
Repair went well. Followed instructions as per websites and looked on YouTube on the same repair.
Found that reconnecting the ribbon cables was a bit tricky as they are tiny
Mijn advies
When reassembling, ensure that all cables are reconnected properly. The ribbon cables you should snap back in from the left to right side or right to left. You should feel a snap or click that it’s in
0 opmerkingen
