« Terug naar alle verhalen
It got the computer working again.
rsimoes -
MacBook Pro 13" Unibody Early 2011
MacBook Pro 13" Unibody Early 2011 Hard Drive Cable Replacement
10 minuten
Easy
Mijn probleem
The computer would no longer boot and came up with a folder with a question mark in it.
Mijn oplossing
The repair was not hard, but a little tedious getting the ribbon cable in place and making the 90 degree bends and sticking it to the bottom of the hard drive area. It was difficult to place the hard drive back in without crushing the ribbon cable and took slightly pushing it away from the hard drive while at the same time sliding the hard drive into the front bracket. The only problem is that the front white LED no longer "breathes" when the computer is asleep as it used to. but it works well. There seems to be a slight difference in the length of the wire, but it will fit. I reused the rubber grommets from the original Apple front bracket, since they have plastic inserts and are of higher quality. (they just slide off)
Mijn advies
Be very careful when making the 90 degree bends and when sticking the wire to the bottom. Work your way from back to front, gently pushing the wire around the 90 degree bends first and then work your finger to the front.
MacBook Pro 13" Unibody (Early 2011-Late 2011) Hard Drive Cable afbeelding
$44.99
0 Opmerkingen
Voeg opmerking toe
