Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
« Terug naar alle verhalen
MacBook Air - Liquid Ingress Repair
Chris Eve -
MacBook Air 13" Early 2015
MacBook Air 13" Early 2015 I/O Board Replacement
10 minuten
Easy
Mijn probleem
A friends MacBook Air had been for a drink and no longer powered on.
Mijn oplossing
Simple, with the right tools, attention to detail, patience and the correct guidance. We were lucky the IO board was the only part damaged by liquid. We also replaced the flex cable which had a red dot underneath (assume this is a liquid sensor apple use for warranty as the replacement was white) to be safe!
Mijn advies
Have everything needed to complete the guide ready before you start. Follow the steps in order and check you've completed them before moving on to the next.
MacBook Air 13" (Mid 2013-2017) I/O Board Cable Afbeelding
$19.99
0 Opmerkingen
Voeg opmerking toe
