Mijn probleem
My brother in law got wood stuck in the lightning connector while cutting logs.
Mijn oplossing
It was the toughest repair I've done yet. But once I got it completely broken down it wa squirm and easy to replace.
Mijn advies
Definitely need to warm the adhesive holding the screen to the frame. I spent 20 minutes alone just working on seperating the screen and glue. Also you can make the repair around the battery very easily. Definitely make sure you have the triangle bits otherwise you'll be stuck.
0 opmerkingen
