Ga door naar hoofdinhoud
« Terug naar alle verhalen
Great Product - Quick Fix
Anthony Capozzolo -
iPhone 6
Afbeelding van het verhaal
iPhone 6 Battery Replacement
45 minuten
Moderate
Mijn probleem
My iPhone 6 battery had reached its limit and was going dead in about 2-3 hours worth of use.
Mijn oplossing
The repair went great. It does require a certain amount of technical skill in terms of not being afraid to take apart an electronic device; removing very tiny screws (and you need to put the same screws back in the same place b/c they are not all the same size!); and disconnecting the screen and battery which requires using tweezers to detach a number of delicate cables.
Mijn advies
Be careful placing the new battery; you need to leave a very tiny amount of extra room of the long side of the battery that faces the center of the battery because the connector that attaches the battery to the phone has a cable that requires it to lie next to the battery -- if you don't leave any room you will have to move the battery, which is impossible once the adhesive strips stick to the inside of the phone when you place the new battery in the phone.
iPhone 6 Battery Afbeelding
iPhone 6 Battery
$29.99
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 73
