« Terug naar alle verhalen
Finally fixed my MacBook Pro!
Jeremy Adams -
MacBook Pro 15" Unibody Mid 2009
Afbeelding van het verhaal
MacBook Pro 15" Unibody Mid 2009 Hard Drive Cable Replacement
30 minuten
Moderate
Mijn probleem
After replacing the DVD drive with a second HDD and the primary HDD with an SSD I thought I was all set for a better computing experience. Unfortunately, after only a couple of weeks the funky hard drive performance I was experiencing before I replaced the HDD with an SSD returned. At the time I thought it was a problem with the motherboard, but eventually ran across the fact that it was probably the hard drive cable.
Mijn oplossing
Straight-forward, painless, and completely solved the problem! I couldn't be happier. I had already upgraded to a newer MacBook for work, but now I've got my old 15" MacBook Pro back up and running. The new OS X El Capitan actually runs very smoothly on my SSD, making this an excellent, like-new test machine and toy for running Linux or Windows on VirtualBox. Thanks, iFixIt!
Mijn advies
If the little pulsating LED light on the front-right corner of your mid-2010 MacBook Pro has stopped working, or doesn't work reliably any longer, it's probably the hard drive cable going bad. Replace the old HDD with a bigger SSD while you've got the machine opened up, and your MacBook will feel like a whole new machine.
MacBook Pro 15" Unibody (Mid 2009-Late 2011) Hard Drive Cable afbeelding
$44.99
0 Opmerkingen
