Ga door naar hoofdinhoud
« Terug naar alle verhalen
Replace the CMOS battery...
Matthew Smith -
iMac Intel 20" EMC 2266
iMac Intel 20" EMC 2266 Hard Drive Replacement
45 minuten
Moderate
Mijn probleem
While you have it apart, replace the CMOS battery. It is 5+ years old....
I used a Duracell CR2032.
Mijn oplossing
Fairly easy, have some superglue or a hot melt glue gun to secure the temp sensor retainer to the hard drive.
Mijn advies
I used a two terabyte Western Digital Black drive as a replacement.
First I used an external case to temporarily hold my new drive, and then installed a fresh copy of Mac OS X El Capitan. I then used Migration Assistant (starts automatically) to move all the data over.
Then I installed the drive.
Look carefully on setting the display and front bezel back.
If it does not sit flush, you are pinching a wire, and need to lift up and look.
0 opmerkingen
Voeg opmerking toe
