Ga door naar hoofdinhoud
« Terug naar alle verhalen
Saved my Macbook Pro from the trashcan.
Luiz Antonio Prior Junior -
MacBook Pro 13" Unibody Mid 2012
MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement
20 - 30 minuten
Moderate
Mijn probleem
My Macbook Pro mid 2012 didn't boot after a forced shutdown. I took it to maintenance and first, they said it was OK, but getting to the store it didn't boot again. Technician said it was a logic board failure. I mentioned the cable, but he said he already tested it.
Mijn oplossing
I decided to browse some more and found many similar reports of faulty flat HDD cables. I decided to give Ifixit a try, and ordered the cable plus some tools for the job. The order came very fast for an international order. It was a matter of following the instructions at Ifixit's website, and the laptop was running again, back from the presumed dead.
Mijn advies
I would say that Ifixit is a wonderful place not only for digging the parts you need, but to see the experiences of users and their issues solved. I wish I had a similar alternative in my country. I would suggest you dig a lot around the web and take with a grain of salt when a technician tells you your machine is gone. Specially when it is something as expensive as a laptop. Thank you, Ifixit!
Spudger afbeelding
Spudger
$3.99
Phillips #00 Screwdriver afbeelding
$6.99
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable afbeelding
$29.99
0 Opmerkingen
Voeg opmerking toe
