It Lives! Breathing life into a dying MBP by replacing the HDD and SATA cable
Ufuk -
Mijn probleem
One day, just out of the blue the laptop wouldn't boot, and when it did it was unbearably slow.. After quite some troubleshooting I narrowed it down to the I/O with the disk. It was either the HDD or the cable!
I tried to isolate the cable from touching the optical drive by some tape, as advised by someone on Amazon, but that didn't solve the issue. Essentially I decided to replace the cable AND the disk, opting to install a 250G SSD disk instead.
Mijn oplossing
How did the repair go? Smooth.. It's a relatively simple fix. Tiny screws and narrow spaces can be a bit annoying if you have large hands or if your fingers arent all that nimble but it's not a difficult repair by any means.
My only concern was with the adhesive on the cable; it's difficult to place the cable correctly, so I waited with removing the coating on the adhesive. The problem is, when the cable is finally in position, you can't really reach under and remove the tape. So I relied on the SSD to keep the cable in place. Hopefully I wont regret that decision.
Mijn advies
Do your homework: troubleshooting, read up on the fix, make sure you have everything you need BEFORE you start diving in.
0 opmerkingen
