Mijn probleem
The old battery was not lasting long.
Mijn oplossing
Everything went pretty much like the instructional video, even though the video did not show how to reinstall the battery connector or the screen. Hooking up the battery connector was also a little uncertain. I could not tell if the connect was aligned before I had to push down to make the connection. You should feel the connector snap into place. It's a subtle snap because it is such a tiny connector.
Mijn advies
I did not remove the 3 screws that held down the connectors that wired to the glass screen, I had another person help me hold the screen while I removed the battery connector and then the battery. I was fortunate in that I only had to pry from the right edge of the battery to get the old battery out. My friend who did the same repair said his old battery was bent before it would come out. On closing the glass screen, make sure the top edge is seated before you push down on the bottom edge. The top edge needs to slip under a lip before you push the bottom edge back down. If you don't, the top edge (where the ear speaker is) will not snap back down. Also try to lay a towel down as a working surface. Should you drop any of the tiny screw, it could bounce off the table and be permanently lost in the carpet. The screws are really tiny.
0 opmerkingen
