Ga door naar hoofdinhoud
« Terug naar alle verhalen
A tight fisted Scott repairing his IMac
Grumpy -
iMac G5 20" Model A1076
iMac G5 20" Model A1076 Hard Drive Replacement
5 - 15 minuten
Moderate
Mijn probleem
The hard drive crashed and was not going to spend the money for a new computer.
Mijn oplossing
The actual replacement of parts was easy, the re configuring and restoring files was a bit trying . I am not a computer guy, I am a race car mechanic, nuts and bolts are easy-peasy. All the reloading of software and recovering of files took about four hours, the drive took less than hour. Everything is working, so I am thinking of trying more of these kinds of repairs. Could be good, could be bad.
Mijn advies
Go at these things with an open mind, the piece does not work before you start so it can only get better!
1 TB 7200 RPM 3.5" Hard Drive Afbeelding
$69.99
Spudger Afbeelding
Spudger
$3.99
T6 Torx Screwdriver Afbeelding
T6 Torx Screwdriver
$9.99
TR8 Torx Security Screwdriver Afbeelding
$5.99
TR10 Torx Security Screwdriver Afbeelding
$5.99
0 opmerkingen
Voeg opmerking toe
