« Terug naar alle verhalen
Banff in the car mix revived!
paterson24 -
iPod 4th Generation or Photo
Afbeelding van het verhaal
iPod 4th Generation or Photo Battery Replacement
15 minuten - 1 uur
Moderate
Mijn probleem
I could no longer operate my iPod. If I did manage to start it up it often sounded like the hard disc was just repeatedly spinning up and it would never complete charging. Also, the center click button was getting really difficult to click.
I really wanted to access some songlists put together during and for some amazing road trips in the USA and Canada.
Mijn oplossing
All went quite easily, once got the case open. I only had two large iPod opening tools, and found the trick was to insert one quite quite forcefully (near the earphone jack as described) with the curved tip down towards the metal case and then it would stay in place - as it had inserted past the thickest part to the tip. Then I could easily slide around to the corner and insert the second opening tool on the long side. The adhesive holding the battery in place is very strong, but again using the opening tool I could insert from the side and underneath the battery and use it to lever the battery free.
The old battery was really swollen (twice as thick as the new replacement) which explained why the center button had become almost impossible to click, and of course, why the iPod had stopped working - it was unable to charge the battery.
As soon as I plugged the iPod into the charger it came to life, and now I have access to music that I have not listened to for 2 years.
Mijn advies
Persevere with the first stages of opening the case, and don't be afraid to use quite a bit of force - but just with the plastic iPod opening tools. I was expecting a large and small opening tool in the repair kit but only received two large opening tools. It turned out they were all I really needed, along with the T6 torx screwdriver.
iPod 4G/Photo Replacement Battery afbeelding
$13.99
0 Opmerkingen
Voeg opmerking toe
