Ga door naar hoofdinhoud
« Terug naar alle verhalen
Used fans work great!
patchesdrywall -
MacBook Pro 15" Unibody Late 2008 and Early 2009
MacBook Pro 15" Unibody Late 2008 and Early 2009 Right Fan Replacement
Moderate
Mijn probleem
My brother's Macbook Pro was making some interesting sounds on top of overheating. We did some research and came across ifixit.com how-to articles. From there, I ordered the fans (used), and the problem was fixed!
Mijn oplossing
Removing and replacing the right and left fans (Macbook Pro 15 mid-2009 2.8 GHz model) was simple. I ordered the required tools (Philips #00 screwdriver, spudger, & anti-static wristband) along with the fans, unscrewed the bottom plate, popped out the connectors with spudger, unscrewed fans, and then did the reverse. Simple!
Mijn advies
2 pieces of advice: use an anti-static wristband and be careful while handling the spudger to disconnect fans.
MacBook Pro 15" (Late 2008-Mid 2012 excluding Mid 2009 2.53 GHz) Left Fan Afbeelding
$39.99
MacBook Pro 15" (Late 2008-Mid 2012 excluding Mid 2009 2.53 GHz) Right Fan Afbeelding
$29.99
0 opmerkingen
Voeg opmerking toe
