Nexus 7 (2013) USB board replacement
Mijn probleem
My Nexus would no longer charge or sync with my PC
Mijn oplossing
Simple, just carefully remove the back from the Nexus, remove 6 screws holding the Usb board and unclip and remove all the cables attached replace the board and reverse the process. Took 5 Min. and now its perfect again.
Mijn advies
The hardest part is removing the back take it slow and gently work your way all around the case. (and remember Youtube is your Friend)
0 opmerkingen
