« Terug naar alle verhalen
"Concrete smack down"
pockits -
iPad 3 Wi-Fi
iPad 3 Wi-Fi Front Panel Replacement
2 - 3 uren
Difficult
Mijn probleem
I took my Otter Box cover off to take a picture of to send back because it had cracked. Started taking notes without the otter box on with my external keyboard, and my pad flew off the keyboard and did a flat faced, face plant on the concrete and shattered my screen. I was not a happy camper
Mijn oplossing
Not so well at first. The iopener instructions say to microwave for 30sec it wasn't loosening up the glue, so I waited as per the instructions and heated again and the opner leaked out from the left corner into my microwave. I wish I had the one that they use in the video or a heat gun. Now with no heat I had to improvise and use a hair dryer which took forever. But finally got the glass off cleaned it up and replaced the glass and did a control check and everything worked.
Mijn advies
Take your time and you will a lot of patience. Also make sure to get the Isesamo opening especially if your glass has cracks the run to the edge. The plastic tools that I got did not lift the glass. Be sure to order a new Bezel. I learn the hard way, because I have to order a new front panel digitizer it did not hold and it popped up and shifted on me. Still works but it is not seated properly.
iPad 3 Front Glass/Digitizer Touch Panel Full Assembly afbeelding
$39.99
0 Opmerkingen
