« Terug naar alle verhalen
Suspect disk drive going bad & slow performance, startup slow progress bar
gchin -
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement
Moderate
Mijn probleem
Macbook Pro starting to crash a few times when using, and reboot or startup encountered slow startup & slow progress bar. Performance was very slow when using... and noticed the laptop was extremely warm where the hard drive is located. Assume the hard drive was going bad...Took my mid-2009 Macbook pro to Apple store to determine if hard drive is bad, after they examine it, they determine that 90% is bad disk drive cable. Disk drive was 100% okay. They can't repair due to it is now consider vintage... well don't carry the part. They pointed me to ifixit web site that carries the part, and if you are handy a DYI person can repair for alot less, or you could send to repair service to fix for ~$100-$150. Part cost ~$40. Part arrived fairly fast. Plenty of Utube videos to show how to replace defective part with new one.
Mijn oplossing
Very easy to repair if you take your time.
Mijn advies
Used tools (small tiny phillip screw driver) from iphone tookit purchased from ifixit a couple year ago to fix broken screen. Have container to hold the tiny screws.
MacBook Pro 15" Unibody (Mid 2009-Late 2011) Hard Drive Cable afbeelding
$44.99
0 Opmerkingen
Voeg opmerking toe
