Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
« Terug naar alle verhalen
Repair went well, not all steps required.
lambdahindiii -
iPhone 5s
How to replace the battery in your iPhone 5s
30 minuten - 1 uur
Moderate
Mijn probleem
Original battery was dying so I put in a new one.
Mijn oplossing
It went well! Took me about 40-60 minutes in total. The old battery was VERY difficult to remove and I ended up destroying it in the process.
Mijn advies
I skipped steps 11-16 and that worked pretty well from me. On another commenter's advice, I simply used some packaging tape to tape onto the top of the screen, over the top of the phone, and onto the back of the phone to hold the display at a right angle to the rest of the device. Saved me all the trouble/risk of disconnecting the display, but if you use this method you should be VERY careful not to hit the display while removing the battery .
iPhone 5s Replacement Battery Afbeelding
$29.99
0 Opmerkingen
Voeg opmerking toe
