Mijn probleem
The rear camera in my iphone 5 failed.
Mijn oplossing
The process went fine. I used the ifixit repair steps. One thing I missed when I re-installed the logic board was I had installed it over the wifi cable which caused me to have to remove the logic board a second time to free it. So be wary of the cables on the side of the
Mijn advies
One thing I missed when I replaced the logic board was I had installed it over the wifi cable which caused me to have to remove the logic board a second time to free it. Also, I had the issue where the it is in constant "searching" mode on the cell radio even though it is working. My date/time was synced (which I read in comments as being an issue) so I just cycled "set automatically" and the dots showed back up. Also, the 1.6mm screw on step 13 would not screw into the standoff screw underneath so I left it out.
0 opmerkingen
