Great Instructional Video--Use Extreme Caution When Opening
Mijn probleem
Battery was lasting 5 or 6 hours at most with no use--maybe 3 hours when using it
Mijn oplossing
its recommended that you use some force to open the case up. I had the suction cup on and was slowly pulling so I could try to get the separator tool in there to open it up but wasnt having any luck. Video says to use some force because the clips are there to hold the pieces in place--I gave it a good tug and ended up ripping the two pieces apart essentially tearing the ribbon cables for the front facing camera, screen connector, and speaker. The video does tell you to be careful that those are there, but probably should give you warning to go slow when trying to open and not recommending pulling with force
Mijn advies
Take your time when using the suction cup to open up the device. If its your first time opening the device it will be difficult. Go slow and pull slowly..get a friend to help. While one person is holding the base and slowly pulling on the suction cup, the friend should try to get the tool in there. Pull too hard and you'll rip apart the ribbon cables connecting the screen and camera to the logic board.
0 opmerkingen
