« Terug naar alle verhalen
really, really easy. everything I needed, and all the info too...
maltovich -
iPhone 5
How to replace your iPhone 5 battery
15 minuten - 1 uur
Moderate
Mijn probleem
My iPhone was 2+ years old and the battery just didn't have the life it once had.
Mijn oplossing
The process was really easy. The iFixit kit had everything I needed to do the repair. I was done with the process in about 10 minutes.
Mijn advies
A couple of things I found:
- After attaching the suction cup to the display, it was hard to get the display to separate from the case to get the opening tool in to the space between them. When I pulled harder, the display came free all at once. I was worried that I might have damaged the cables from the display to the logic board (I didn't). When I looked at the forum, I saw others had the same experience. I took the phone apart again, and was able to open the case without pulling the display so far. It's easier to control if you're expecting it.
- When I put the phone back together, I noticed a hotspot at the top of the display, that seemed like it was in the same location as the shield over the cable connectors (which is removed and replaced during the battery replacement). I opened the phone and removed and replaced the shield, making sure everything was seated. When I put the phone back together, it worked perfectly. I think the shield was pressing against the display, causing the hotspot.
iPhone 5 Replacement Battery afbeelding
$29.99
0 Opmerkingen
Voeg opmerking toe
