« Terug naar alle verhalen
iPhone 5s - Shattered display replaced
barbaianni -
iPhone 5s
Afbeelding van het verhaal
iPhone 5s LCD and Digitizer Replacement
30 minuten - 1 uur
Moderate
Mijn probleem
I wanted to change the display of a friend's iPhone 5s. I don't know exactly how it happened but the screen was shattered. She has two small kids so they probably had something to do with it :-)
Mijn oplossing
The repair went pretty well. The first time I tried to turn it on it didn't turned on, it would vibrate multiple time but the screen didn't respond...but I quickly found the solution in the "Answers" section. I just had to open again the iphone, unplug the battery connector, press shortly the on/off button, plug the battery connector back to the main board and boom it worked.
After that I had another little glitch: the phone didn't find any signal. On the up left corner it was written "searching". Unfortunately I don't exactly know what fixed the problem. I did a reset of the network settings, but didn't fix the problem right away. Then I did something else (sorry but I forgot what, besides praying...) and after a while it asked the sim card pin code and it worked!
Mijn advies
If you encounter any problem look for the solution in the "Answers" sections....it was really helpful for me.
Suction Handle afbeelding
Suction Handle
$2.99
0 Opmerkingen
