« Terug naar alle verhalen
Adhesive, the New Enemy
agentgray -
iPad Air Wi-Fi
iPad Air Wi-Fi Front Panel Assembly Replacement
1 - 2 uren
Difficult
Mijn probleem
The iPad air had a severe crack (with a hole in it) by the camera that split into two cracks that covered 2/3 of the screen. The crack just happened while I was *holding* it.
Mijn oplossing
In my case, the iOpener did not get hot enough to loosen the adhesive. I had to recruit another person to run a hot air gun over the edges 30 seconds at a time. I taped over the digitizer, but just like the guide said, it shattered and cracked even worse. The suction cup became useless. Essentially, I had to wear protective gloves and scrape out the glass along the edge. Everything else went fine, but I have one small shard of glass between the digitizer and LCD. It's almost exactly in the center. I thought I got them all out, but one must have snuck by. This digitizer now pops a little at times if it's pressed in the the right place. This is also right by the camera. My guess is that this is a design flaw with the iPad itself. There's nothing to reinforce it. After doing some research on the web, this is a COMMON area for the iPad Air to crack.
Mijn advies
The hot air gun seemed to work better, but we were *very* careful. Take your time. Use the picks. Make sure any pieces of broken glass are not on your LCD. Maybe use something around the camera to reinforce the digitizer?
iPad Air Screen afbeelding
iPad Air Screen
$49.99
0 Opmerkingen
Voeg opmerking toe
