Mijn probleem
The phone was dropped and the top half of the screen shattered
Mijn oplossing
It was my granddaughters phone so I enlisted her help. We called up the repair directions. She read them off and I followed step by step. I purchased the magnetic work pad--I highly recommend doing so. The very small screws could easily be lost. We took our time and made sure we carefully followed every step.
When we turned it on after we completed the repair, it worked!
Mijn advies
As I mentioned before, the magnetic pad really helped to organize the event. We labeled each block with the name of the area and the color of the band outlining the screw (as shown in the online instructions--some are different lengths and then we were sure we were putting them back where they belonged). I also recommend working on a bath towel (with some fluff to it) for two reasons: 1) helps to keep from scratching the phone or work surface and 2) if a screw should get loose while removing or replacing, the towel caught it. (Believe me, you don't want to have to look for one of these screws!).
Last but not least, be patient and take your time. It will help to ensure success.
0 opmerkingen
