iFixit Precision 4 mm Screwdriver Bit
  • iFixit Precision 4 mm Screwdriver Bit
US$ 2,99
US$ 2,99
We zullen een bericht sturen als het product weer op voorraad is.
Productdetails
Beschrijving
Beschrijving
iFixit Precision 4 mm Screwdriver Bits have been designed with a longer neck for a deeper and more precise reach. These bits are featured in our Mako Driver Kit - 64 Precision Bits and Manta Driver Kit - 112 Bit Driver Kit.
Reparatieverhalen
Tristan van Triest's Story Photo #1479474
Tristan van Triest's Story Photo #1479477
Tristan van Triest's Story Photo #1479478
Mijn probleem
The iPhone was scuffed in many ways, so I was like, let's buy a new case, screen, home button, etc...
Mijn oplossing
Everything went well, except for the screen, which still had some white pressure spots, even though it was a new screen.
The volume buttons are a pain in the **** to replace, but with enough patien . . .
HITGFRY's Story Photo #1301867
Mijn probleem
Camera would not power up. I found that the CMOS battery receptacle solder points had come undone. I tried to re-solder but it didn't work. I think the poor connection damaged something else in the mother board. I purchased a manufacturers refurbished MB on eBay for $159.00.
Mijn oplossing
Replaced the main board. . . .
Mijn probleem
Original battery was not holding a charge. Phone started shutting down at random times.
Mijn oplossing
Exactly as advertised. Tiny screws are really, really tiny!
Mijn advies
Phone was an eBay purchase... discovered that the previous owner had been inside the case, had lost a bunch of screws, and had misplaced the battery con . . .
Mijn probleem
2 broken foot pads.
Mijn oplossing
Extremely easy. Spent more time cleaning out dust bunnies than replacing the foot pads.
Mijn advies
Make sure that all the base attachment screws are laid out in an orderly fashion so reinstallation goes quickly and w/o a hitch
Mijn probleem
Broken screen
Mijn oplossing
I’ve done a few of these repairs so it went very well except I didn’t realize the iPhone 7 had a new type of screw inside the phone. I had to put off the repair until I was able to order the tri-point driver
Mijn advies
Don’t forget to order the Tri-point Y000 driver bit and a handle to go wit . . .
Mijn probleem
Damaged dock, slow phone.
Mijn oplossing
The repair went beautifully. Could have used stereo magnifiers, though. Did a cold reboot, then discharged to 10% followed by a non-stop charge to 100%. Had a fast phone again with long battery life.
After about a week, it wouldn’t take a charge unless the battery was dow . . .
Mijn probleem
Another broken iphone screen. I repair phone and other electronics for a living. This was a family members phone so not a paid job but you always help out family.
Mijn oplossing
Like clock work. iPhone 7 in minuets.
Mijn advies
Since this was a family members phone there is no advice. But if you repairs as much as I do treat e . . .
Mijn probleem
Had to replace a broken screen
Mijn oplossing
Using the guide from the site, I was easily able to take the watch apart and replace the screen without a hitch.
Mijn advies
It's easier to tear apart using a great shrink gun to help loosen the seal around the edges.
Mijn probleem
Broken Screens or other broken parts
Mijn oplossing
well i fix all kinds of phones a lot of iphones and i lost 2 of my bits so i did not know what to do i contacted ifixit and they just happen to sell just the bits so i got 2 of them and love fixing phones im glad they had the bits i need
Mijn advies
you need to order bits if y . . .
Mijn probleem
The battery was old and had gone through many cycles. It was not holding charge like it used to and would often require charging throughout the day.
Mijn oplossing
The repair went really well. The instructions were easy to follow as well as the plethora of resources on ifixit as well as youtube. The only annoying p . . .
Geef meer weer
