iFixit Opening Tool
  • iFixit Opening Tool / Individual
  • iFixit Opening Tool / 5
  • 360°
360
iFixit Opening Tool
Plastic tools designed to get you in the tightest cracks, without damaging your treasured devices.
US$ 4,99
US$ 4,99
We zullen een bericht sturen als het product weer op voorraad is.
Productdetails
Beschrijving
Beschrijving
The primary tool for opening everything
  • Custom-designed handle provides no-slip opening power with plenty of grip.
  • Tough-yet-soft material prys open the tightest cracks, but won't scratch or mar your workpiece.
  • Two tips provide alternate opening options: Wedge for breaching, and Hook for lifting and levering.
  • Convenient pack of 5 tools, for 10 total prying tips!
Productvideo
Reparatieverhalen
Magnus Flovikholm Røyset's Story Photo #1445041
Magnus Flovikholm Røyset's Story Photo #1445040
Magnus Flovikholm Røyset's Story Photo #1445043
Mijn probleem
A couple of months ago, my four year old iPhone 5S had a severe shutdown. It was all black, and wouldn't start until after a couple of hours connected to the charger. I panicked, thinking the phone was dead.
Luckily it booted up again, but afterwards I have had to charge my phone every night. If no . . .
Mijn probleem
My battery was running out too quickly. Had to charge my phone at least 3 times during the day. The fg_fullcapnom showed the capacity to be 1145, instead of 3000mAh original capacity.
Mijn oplossing
YouTube was a big help. I used their complete detailed guide to replace my battery. It went perfectly well.
Howe . . .
Mijn probleem
My keyboard was getting worn out and the 'm' key didn't always work which is aggravating.
Mijn oplossing
oldturkey03 wrote clear instructions and with good pictures. I found that the screws weren't always where they were shown but that is probably due to HP G72 manufacturing changes. The keyboard is a 'bear' to get . . .
Mijn probleem
The problem is the NOOK HD...what a RIP-OFF! Barely used, yet when not in use, battery dies...after stressing on how to open this item, finally ordered tool....worked great, the tool that is...NOT the Nook...more $$$$ down the drain...#buyingbooksinstead
Mijn oplossing
The replacement of BRAND NEW BATTERY was the h . . .
Mijn probleem
Slowing performance on my phone.
Mijn oplossing
Repair went well following the instructions.
Mijn advies
I replace my battery, screen, and lightning connector. I recommend going through the guides while you wait for your parts in the mail. Remember to lay the screws out in a specific order since every group has all different si . . .
Mijn probleem
Battery was old and phone wasn't holding a charge.
Mijn oplossing
Repair was much faster and easier than the guide and online posts. Took me 10 minutes with the standard iFixIt repair kit, which had everything needed and more. Now my iPhone battery and speed is back to normal. Great website, videos and guides!
Mijn advies
Step . . .
Mijn probleem
My iPhone 6 Plus display recently started flickering and, at times, became unresponsive unless I literally forcibly twisted the phone in order to get it to respond. This issue was extremely annoying and frustrating, especially when trying to answer a call. So, I had three choices. Buy a new iPhon . . .
Mijn probleem
The top corner of my screen cracked a whole hour after I took my case off, so I decided to get in touch with my iFixit friends to get it repaired. While I was doing that, I decided to replace the battery as well.
Mijn oplossing
It was a piece of cake! The Repair Kit had everything I needed, and was labeled perfectl . . .
Mijn probleem
My phone would need to be charged at least 2-3 times a day with moderate normal use. There were times where it would shut off completely with 50-80% battery life showing. Very hard to rely on a phone under the conditions so I purchased the battery fix kit from ifixit and could not be happy with how . . .
Mijn probleem
Found an old iPod, thought it was a gonner. After a quick Google I found this website couldn't believe they had everything I needed and instruction! Anyway super easy super fast delivery and now I'm jamming like the old days.
Mijn oplossing
Went great really easy.
Mijn advies
Raise your dead....devices.
Geef meer weer
