iFixit Opening Picks (Set of 6)
  • iFixit Opening Picks (Set of 6) / New
  • 360°
360
US$ 4,99
US$ 4,99
We zullen een bericht sturen als het product weer op voorraad is.
Productdetails
Beschrijving
Beschrijving
Pick your way to repair!
  • 6 very thin opening picks
  • Can be used for prying, sliding, separating, and air guitaring.
  • These picks are especially useful for prying open iPads and other glue-laden devices.
Reparatieverhalen
Scott Cassio's Story Photo #885867
Mijn probleem
Cracked front panel assembly
Mijn oplossing
The repair is pretty straight forward until the conclusion which states, 'But first ensure to place a narrow piece of tape over the copper/silver at the bottom of the digitizer to the left and right of the home button.'
Since there was no tape in those areas when I took . . .
Mijn probleem
Old battery couldn't hold a charge for long.
Mijn oplossing
Your tools made getting into the case easy. The only problem was getting the old battery out... Too much original glue!
The supplied tools made the job much easier.
Mijn advies
Don't try to open the case with your fingernails!
Mijn probleem
Spider web screen
Mijn oplossing
Repair went very well instructions were plain enough was a little nervous of crushing a connector after the first one was in it was smooth sailing about an hour to do
Mijn advies
Go slow take your time and follow instrutions
Mijn probleem
Accidentally dropped my phone right on the back.
Mijn oplossing
With a heat gun on low the glue softened up very easily. Needed something sharper and thinner to get under the glass but once I did it peeled off easily. Removed all the old glue with a knife to hopefully retail some water resistance.
Mijn advies
Use the heatgun . . .
Mijn probleem
Screen was badly cracked after bing dropped on corner of iPad.
Mijn oplossing
Repair went smoothly. No major issues but needed another tool to make it really work.
Mijn advies
Need to stay patient as it's tedious work getting the screen off. After that it's pretty easy. The plastic tool to pry open the screen from the edge isn' . . .
Mijn probleem
My wife's phone. She cracked her LCD screen
Mijn oplossing
The "Ifixit" video manual was to the point and quite accurate except a couple of things. On this particular phone the original adhesive refused to let go after heating the chassis several times. The iSclack was not strong enough to lift the rear cover loos . . .
Mijn probleem
My power switch was stuck. I bought a spare part off eBay.
Mijn oplossing
You guys rated the fixability a "1" and I completely agree. What a pain. I was able to get the switch replaced and the unit works except that when I was using the picks I pushed one in too far and it broke the digitizer membrane on the top-le . . .
Mijn probleem
Cracked Screen
Mijn oplossing
Great!
Mijn advies
Becareful where you order your screens. I had to do this twice!!
Mijn probleem
Kindle would not charge unless you did the wire dance ( moved it all over) until you find the spot that if you're lucky will charge after you sit it down . Got to the point that I had to do it without moving the Kindle.
Mijn oplossing
Very well, you just have to pay attention to details.
Mijn advies
Have a clean surface and all . . .
Mijn probleem
iPad 4th Gen WiFi with a broken front glass.
Mijn oplossing
The instructions were great except that for some reason, they assumed that I would be replacing an intact glass panel. Mine was broken in 4 lines, and every time I got to another break, it would shatter down to powdered glass and glue (Yes I know it is 3M . . .
Geef meer weer
