Universal Bit Kit
  • Universal Bit Kit / New
  • 360°
360
Universal Bit Kit
The complete bit set for any repair enthusiast.
$99.99
$99.99
We zullen een bericht sturen als het product weer op voorraad is.
Productdetails
Beschrijving
Beschrijving
  • 128 steel bits in both 4 mm and 1/4" sizes for precision work and large torque application.
  • CNC machined aluminum driver handles for both 4 mm and 1/4" bits provide plenty of grip while driving screws.
  • Elegant oak case keeps all components secure and conveniently displayed.
Bit List
  • Phillips 000, 00, 0, 1, 2, 3
  • Flathead 1, 1.3, 1.5, 2, 2.5, 3, 3.5, 4, 5, 6, 7, 8 mm
  • Torx T2, T3, T4, T5
  • Torx Security TR6, TR7, TR8, TR9, TR10, TR15, TR20, TR25, TR27, TR30, TR35, TR40
  • Hex 0.7, 0.9, 1.3, 1.5 mm
  • Hex Security 2, 2.5. 3, 3.5, 4, 5, 6, 7, 8 mm
  • Hex SAE 1/16
  • Hex Security SAE 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4
  • Nut Driver 2.5, 3, 3.5, 4, 4.5, 5, 5.5, 6, 7, 8, 9, 10, 11, 12 mm
  • Nut Driver SAE 1/4, 3/8
  • Square 0, 1, 2, 3
  • Pozidriv Pz0, Pz1, Pz2, Pz3
  • JIS J000, J00, J0, J1
  • Torq-set 6, 8, 10
  • Tri-wing 0, 1, 2, 3, 4
  • Tri-point Y000, Y00, Y0, Y1
  • Pentalobe P2, P5, P6
  • Clutch 1, 2, 3
  • Gamebit 3.8, 4.5 mm
  • Spanner 4, 6, 8, 10, 12
  • Triangle 2, 3 mm
  • Spline M5, M6, M8
  • Oval Bit
  • SIM Eject Tool
  • Magnetic Pickup Tool
  • Schrader Valve
  • Hook and Loop Fastener
  • 1/4" to 4 mm drive adapter
  • 1/4" driver to 1/4" socket adapter
  • 1/4" driver to 3/8" socket adapter
  • 1/4" socket to 1/4" driver
Productvideo
Reparatieverhalen
Avatar
Benjamin Rodriguez's Story Photo #1013595
Mijn probleem
Battery is damaged
Mijn oplossing
Quite easy
Mijn advies
If you put more guides that are good to learn
Avatar
Mijn probleem
User spilled coffee onto their keyboard, computer shut off.
Mijn oplossing
Better than anticipated. First in-house repair of a logic board.
Mijn advies
Magnetic board to organize screws and the 128-bit kit to have everything.
Avatar
Mijn probleem
My Apple watch screen suddenly came off of the frame as the adhesive material must have some how been damaged. So the screen was hanging from the frame by a few tiny connections!!!!
Mijn oplossing
I took it to Apple to get it fixed and they quoted me 3 weeks time plus 275$+13% tax to fix it as I was out of warranty . . .
Avatar
Mijn probleem
The Problem started when my dog knock over water on my wife mac.
Mijn oplossing
The repair went well, though i should of bought the ifix it business tool kit because some of those cable are really small.
Mijn advies
I never done a repair that did not had any remaining screws. Just follow the step that Ifix it provides and you w . . .
Avatar
Mijn probleem
It had been dropped
Mijn oplossing
My blind grandmother could have fixed it....
Mijn advies
If you need help go to ifixit
Avatar
Mijn probleem
The battery of my Macbook Pro 15 - 2011 died on me.
Mijn oplossing
It took about 7 min and was great.
Mijn advies
Just read the instruction before you order.
Avatar
Mijn probleem
The current 500GB drive had run out of space, so we upgraded to 4T.
Mijn oplossing
Everything went well, however a word of caution. The video cable mount is very tiny and you need small hands to reseat it.
Mijn advies
You don't need to remove the LCD screen, you can reach the screws that hold the drive in place by simply liftin . . .
Avatar
Mijn probleem
Problem - Daughter's Boyfriend Electrical Engineer - Idea for gift!
Mijn oplossing
He loved it! Several times while he was at our house, I found him simple pulling out each bit and playing with the two drivers. My daughter said he had to hide them from his Dad. Maybe Dad will get a set of his own.
Mijn advies
Oh yes, advice... . . .
Geef meer weer
