TR8 Torx Security Screwdriver
  • TR8 Torx Security Screwdriver
  • TR8 Torx Security Screwdriver / iFixit - Made in Germany
  • TR8 Torx Security Screwdriver / Moody - Made in USA
US$ 6,99
US$ 6,99
We zullen een bericht sturen als het product weer op voorraad is.
Productdetails
Beschrijving
Beschrijving
Use this precision Torx TR8 screwdriver for DIY or professional electronics repair. This driver is required screwdriver for opening up the PlayStation 3 Slim. The screwdriver head is also known as the Torx Security TR8 and is compatible with standard Torx T8 fasteners.
The iFixit Torx TR8 screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision Torx TR8 screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
Reparatieverhalen
Kenneth Sayers's Story Photo #736122
Mijn probleem
The keyboard stopped working when water was spilled on it.
The repair shop wanted too much money so we just used an external keyboard. We finally found this an unacceptable solution.
Mijn oplossing
We followed the iFixit instructions. The repair was almost flawless. The microphone connection to the I/O board bro . . .
Eric Outen's Story Photo #835106
Mijn probleem
This wasn't necessarily a fix, but I wanted to speed up my 2007 MacBook because it still works great for Photoshop and Illustrator. I was also holding off upgrading the OS to Lion until I could get an SSD so the installation process would be less tedious. I purchased a Crucial 240GB SSD from Amazon . . .
Mijn probleem
Removed the hard drive myself for disposal. The Apple Store wanted several hundred to do that.
Mijn oplossing
Great
Mijn advies
Use YouTube for stuff
Mijn probleem
Intermitent failure in the MBP display, when screen angle changed.
Mijn oplossing
The repair went with no problems.
Mijn advies
The assembly sold by iFixit simplifies considerably the repair.
Mijn probleem
My joystick wouldnt go to the top left corner.
Mijn oplossing
I spent about $5 on a torx screwdriver, and then about 15 minutes following this guide. It was really quick and easy. There was a loose piece of plastic restricting my joystick's movement, once I moved that back to its proper place the controller worked . . .
Mijn probleem
Needed to upgrade the SSD drive
Mijn oplossing
Great - The iMac runs like it is brand new
Mijn advies
Pricing and Shipping were hassle-free
Mijn probleem
The mini wasn't broken, but the stock hard drive was of the slow 5400 rpm variety, which made the computer itself very slow when running OS X 10.11. So I wanted to find out if I could replace its hard drive with a speedier SSD, and ifixit had the tools and instructions I needed.
Mijn oplossing
The repair went fine. . . .
Mijn probleem
Fractured display College "cleaning" accident....
Mijn oplossing
Smooth, great reassembly tips - 45 minutes and looks like new!
Mijn advies
Read the guide, all the way through...
Mijn probleem
En dormant, j'avais malencontreusement cassé l'écran de mon MacbookPro Retina 13", il était au fur et à mesure devenu tout noir, impossible de l'utiliser sans un écran externe.
Mijn oplossing
Cela a prit en tout et pour tout 20min.
Le tutoriel est très bien expliqué, je conseille tout de même d'acheter le m . . .
Mijn probleem
My early 2009 iMac was really lagging. I hated the ideas of buying a new one when most of the hardware was still in great shape. Therefore I decided to upgrade the hard drive to a solid state.
Mijn oplossing
Great! The performance has been fantastic and it really has given my computer and new life. Working slowly . . .
Geef meer weer
