TR7 Torx Security Screwdriver
  • TR7 Torx Security Screwdriver
  • TR7 Torx Security Screwdriver / iFixit - Made in Germany
US$ 6,99
US$ 6,99
We zullen een bericht sturen als het product weer op voorraad is.
Productdetails
Beschrijving
Beschrijving
Use this precision Torx TR7 screwdriver for DIY or professional electronics repair. The screwdriver head is also known as the Torx Security TR7 and is compatible with standard Torx T7 fasteners.
The iFixit Torx TR7 screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision Torx TR7 screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Reparatieverhalen
Mijn probleem
I had four screws strip their head. No fault of IFIXIT.
Mijn oplossing
I got a stripped head repair kit for Xmas and was able to get the screws out and then back un.
Mijn advies
Do not think anyone will have the problem I had but if you do get a stripped head kit. The tools from Ifixixit are all you need.
Mijn probleem
I had dropped my laptop because my dog jumped on my lap and since then the right speaker sounded blown.
Mijn oplossing
I took the afternoon of, poured a glass of cold beer and sat down with the patient. Carefully I followed the instruction on the website through my IPad. Using the tools I bought off this site, I op . . .
Mijn probleem
too expensive to send to Toshiba. Decided it would be a simple procedure to do it myself - with the right tools
Mijn oplossing
Very well. researched procedure on internet and replaced battery very easily
Mijn advies
Do lots of research before attempting repair. Most hardware issues then become easy to fix.
Mijn probleem
Display screen change.
Mijn oplossing
Well. Easy to use products.
Mijn advies
Spudger is very light build, it is not to be used to apply strength or else it will break in no time, which happened to me.
Mijn probleem
I wanted to upgrade my Macbook Pro's SSD from 128gb to 256gb.
Mijn oplossing
I followed iFixit's step by step instructions, and everything went smoothly.
Mijn advies
I know it might be a little scary doing this the first time (It was for me). Don't worry to much about hurting the machine though. Macs are built strong and are . . .
Mijn probleem
in repair centre it coast twice more and takes two months. I don't know peoples who were satisfied such repair
Mijn oplossing
today i fixed my macbook pro. it took around 2 hours. With your guide and instruments it was very easy.but i got 2 item superfluous.First it is plastic pull tab of the microphone ribbon cab . . .
Mijn probleem
Motorola XOOM Won't Charge or Power On
Mijn oplossing
Read on a forum that one person said that unplugging the battery and reconnecting it would solve this problem so I ordered the 3 items from IFixit that I needed to get inside. The repair was a success. I removed the battery connection inside and reconnected and . . .
Geef meer weer
Klanten die dit kochten, kochten ook
