TR10 Torx Security Screwdriver
  • TR10 Torx Security Screwdriver
  • TR10 Torx Security Screwdriver / iFixit - Made in Germany
  • TR10 Torx Security Screwdriver / Moody - Made in USA
US$ 6,99
US$ 6,99
We zullen een bericht sturen als het product weer op voorraad is.
Productdetails
Beschrijving
Beschrijving
Use this precision Torx TR10 screwdriver for DIY or professional electronics repair. The Torx TR10 screw is a common security screw used in electronics. The screwdriver head is also known as the Torx Security TR10 and is compatible with standard Torx T10 fasteners.
The iFixit Torx TR10 screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision Torx TR10 screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
Reparatieverhalen
Ahmed Lotfy's Story Photo #738396
Ahmed Lotfy's Story Photo #738398
Ahmed Lotfy's Story Photo #738401
Mijn probleem
To replace my 2639 iMac (27" late 2013) HDD with Samsung 850 PRO SSD
Mijn oplossing
It went smooth, thanks to iFixit guides, videos, and tools
Mijn advies
Take your time to plan and prepare for it, handle the screen with extra care, no need to completely remove the left speaker if you plan to replace the HDD; only moving it a l . . .
doshry's Story Photo #695092
Mijn probleem
Had to upgrade my G4 Cube!
Mijn oplossing
Perfect! I feel like a brain surgeon!
Mijn advies
Make sure you get the right tools and follow the right guides! I know a website :-p
Mijn probleem
Made the mistake of buying the "cheap" imac for may daughter with an HDD, i decided to replace the drive with a samsung 850 Evo 500GB SSD.
Mijn oplossing
Repair is super easy and anyone can do it,.
50% of the repair time was spent on removing the old adhesive from the display and the case.
The imac went from 1:22se . . .
Mijn probleem
Repaie guide used was iMac Intel 17" hard drive replacement
My hard drive on my 10 year old iMac G5 was in obvious distress. Utility check indicated it needed to be replaced. Of course it is out of warranty so I decided to tackle the job myself.
Mijn oplossing
I could not believe how easy it was. The instructio . . .
Mijn probleem
to replace my 27" iMac 1TB HDD with Samsung 850 PRO 512 SSD
Mijn oplossing
It went perfect; thanks to iFixit guides and videos
Mijn advies
take your time to prepare for this, a clean area and quiet place will help a lot. handle the screen with extra care, and there's no actual need to remove the left speaker completely if you j . . .
Mijn probleem
My 2012 iMac turned to be very slow with the latest OS X because of the poor spinning drive performance. Decided to replace it the last Samsung 850 EVO SSD.
Mijn oplossing
With the tools and instructions from ifixit, the whole replacement only took me about 1 hour, much easier than I expected.
Mijn advies
The only advice is to . . .
Mijn probleem
The Mac Mini I had was extremely slow and thankfully had the ability to repair the processor, I did so.
Mijn oplossing
It went well, the tools I purchased did the job masterfully.
Mijn advies
Be patient, be kind, and use cable ties.
Mijn probleem
HDD was failing. Decided to replace it with an SSD.
Mijn oplossing
Everything went smoothly in terms of the hard drive replacement in my iMac with one notable exception. I cracked the display while removing it. This was entirely my fault, though. iFixit's tools and tutorials were fantastic. Highly recommend if you' . . .
Mijn probleem
The hard drive crashed and was not going to spend the money for a new computer.
Mijn oplossing
The actual replacement of parts was easy, the re configuring and restoring files was a bit trying . I am not a computer guy, I am a race car mechanic, nuts and bolts are easy-peasy. All the reloading of software and rec . . .
Mijn probleem
The security and torx bits were giving me problems and causing me to not be able to move ahead with my project.
Mijn oplossing
thanks to ifixit and the 2 tools they suggested o have all the parts out I needed and am well on my way to the finished project.
Mijn advies
Wish I had looked here earlier!
Geef meer weer
