Suction Handle
  • Suction Handle
  • Suction Handle
  • 360°
360
Suction Handle
US$ 2,99
US$ 2,99
We zullen een bericht sturen als het product weer op voorraad is.
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Productdetails
Beschrijving
Beschrijving
  • Light-duty suction cup for removing phone and tablet glass panels.
  • 45 mm (1.875 inch) diameter.
  • Folding plastic handle.
  • For a suction cup with a larger grip we also carry a Heavy-Duty Suction Cup.
Reparatieverhalen
Avatar
Jonathan Pitcheralle's Story Photo #1320035
Mijn probleem
The OEM battery on my iPhone 6 was not sustaining the same battery life it once did. Following the recent Apple news indicating that older batteries with degraded performance cannot run the iPhone at peak operating conditions, I decided to just replace the battery. Battery Life app was showing that . . .
Avatar
jakeisbill's Story Photo #1044071
Mijn probleem
My Dad's iPhone 6 was out of warranty and the fee was quoted at $309 USD to repair his earpiece.
Mijn oplossing
The instructions were spot on. I especially liked the little remarks below the instructions telling you to pay extra attention to that step while reassembling.
Mijn advies
Keep up the excellent work.
Avatar
Mijn probleem
iPhone 5 would not startup at all. Nothing but a battery icon and no manner of searching could locate a real fix so it was time to see about either upgrading or replacing the battery. Sorry, did not get any pics to upload.
Mijn oplossing
Followed all the steps in the guide as laid out and the replacement went sur . . .
Avatar
Mijn probleem
The Battery died on my 13 year old's iphone 6. The thought of going to the mall an hour and a half away and waiting in the apple store prompted me to try this. We couldn't be happier with the results
Mijn oplossing
The repair went off without a hitch. We heated the phone a little ahead of time, and it popped right . . .
Avatar
Mijn probleem
iPhone 6 Battery Replacement
Mijn oplossing
After 4 days battery died would not charge!
Mijn advies
make sure battery is new!
Avatar
Mijn probleem
Hard drive was dead, bought the machine for $200 with a known dead HD
Mijn oplossing
Perfect
Mijn advies
The cables were on both sides of the underside of the screen. Rather than lifting the screen, it was easy to shift the screen horizontally to expose the connectors one by one.
Avatar
Mijn probleem
Original lcd screen developed a black strip down the middle.
Mijn oplossing
Repair went well except in the instructions it was specified to use a 6.5 torque to remove hinge screws when a 6 is actually required. Luckily a 6.5 doesn’t exists!
Mijn advies
Take your time and don’t rush your repair. When using the heat gun t . . .
Avatar
Mijn probleem
Initially my wife couldn't charge her phone and after trying multiple cables it became clear the issue was the phone itself, so I purchased the replacement assembly.
Mijn oplossing
This phone had the smallest components I have ever worked with. After putting in the assembly we found that the phone charged fine but . . .
Avatar
Mijn probleem
My wife's best friend has an iphone 6... After 2+ years, she would charge it for the night and when she woke up, battery displayed 100%. 12 minutes later, it would shut off. If she didn't use it at all, it would last 30 minutes. She constantly had to keep a large external battery pack with her to . . .
Avatar
Mijn probleem
The battery life of my phone was poor, maybe 36 hours if I didn't use the phone at all.
Mijn oplossing
It wasn't hard at all, getting the stock battery out was a little difficult since there was some type of adhesive holding it to the phone chassis.
Mijn advies
I used a hose removal tool for cars to get underneath the stock bat . . .
Geef meer weer
