Soldering Workstation
  • Soldering Workstation
$49.99
$49.99
We zullen een bericht sturen als het product weer op voorraad is.
Verspreid de kerstsfeer
Krijg 12€ korting op je aankoop van 50€ of meer met de code FIXMAS12
Productdetails
Beschrijving
Beschrijving
The Universal Soldering Station
  • Don't let blown capacitors or fried transistors stop your electronics! With this soldering station, you'll have everything you need to be the ultimate solder soldier.
  • Build your own speaker cables for that extra audiophilliac edge, or get hacking on a brand new robotics project. The possibilites are endless.
  • Looking for a great project to jumpstart your soldering career? Check out our Electronics Skills Kit 101.
Workstation Kit contains:
Available for shipment only to the USA due to voltage requirements.
Reparatieverhalen
Mijn probleem
None
Mijn oplossing
I just wanted a good set of quality tools around in case anything became an issue. I'd rather be able to fix it right away rather than wait until I have an issue. I am very pleased with the quality of product I received.
Mijn advies
NA
Mijn probleem
Not working after splushdown.
Mijn oplossing
Not well I broke more than I fixed.
Mijn advies
BE CAREFUL!!!!
Mijn probleem
Having a baby requires some good tools, specifically a white noise machine and a baby monitor. Imagine the chances of both breaking in the same week. The manufacturers told me that they would not repair and I could not return so the only hope was to buy new ones (not happening).
Mijn oplossing
Cake. I used my solde . . .
