Soldering Station
  • Soldering Station
  • Soldering Station / Economy
Soldering Station
Only available in the United States.
US$ 24,99
US$ 24,99
We zullen een bericht sturen als het product weer op voorraad is.
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Productdetails
Beschrijving
Beschrijving
Take your repair to the next level! This soldering iron opens the door to a multitude of DIY repairs, from replacing individual components on circuit boards to joining loose wires together. The possibilities are endless.
We recommend purchasing solder, heat shrink tubing, and desoldering braid as they are not included with the soldering station. Better than a wet sponge, our soldering tip cleaning ball quickly cleans the tip without leaving residue. We also carry replacement tips.
This product is also available as part of the Soldering Workstation.
Available for shipment only to the USA due to voltage requirements.
Reparatieverhalen
Avatar
Mijn probleem
Battery wouldn't hold a charge
Mijn oplossing
Replaced the battery but I the battery won't charge
Mijn advies
Get an extra battery
Avatar
Mijn probleem
After charging overnight my battery would go to red line in a few hours.
Mijn oplossing
The repair went very smoothly. The hardest part was getting the ipod apart. The 7 Philips screws were difficult. Of the 7, 5 came out ok, but 2 had head damaged by the time I was done.... but there was enough left to reassemb . . .
