SIM Card Eject Tool
  • SIM Card Eject Tool
SIM Card Eject Tool
$2.99
$2.99
We zullen een bericht sturen als het product weer op voorraad is.
Mac RAM Kits
Versnel je Mac. Breid zijn geheugen uit.
Mac RAM Kits
Haal meer megabytes uit je Mac.
Productdetails
Beschrijving
Beschrijving
The pinnacle of modern ejection technology.
  • One part handle, one part actuator, combined to form the most elegant, simple, and utterly effective ejection tool conceivable.
  • Use this tool to safely remove the SIM card from your Apple GSM/LTE devices (iPhones and iPads).
  • Treat your iPhone and iPad with the respect and care that it deserves, and not some pernicious paperclip.
Compatibiliteit
iPad 2 GSM
16 GB
32 GB
64 GB
iPad 3 4G
16 GB LTE/CDMA
16 GB LTE/GSM
32 GB LTE/CDMA
32 GB LTE/GSM
64 GB LTE/CDMA
64 GB LTE/GSM
iPad 3G
16 GB
32 GB
64 GB
iPad 4 CDMA
16 GB
32 GB
64 GB
iPad 4 GSM
16 GB
32 GB
64 GB
iPad 5 LTE
AT&T
Sprint
T-Mobile
Verizon
iPad Air 2 LTE
128 GB
16 GB
64 GB
iPad Air LTE
128 GB
16 GB
32 GB
64 GB
iPad Mini 2 LTE
128 GB
16 GB
32 GB
64 GB
iPad Mini 3 LTE
128 GB
16 GB
64 GB
iPad mini 4 LTE
128 GB
16 GB
64 GB
iPad Mini CDMA
16 GB
32 GB
64 GB
iPad Mini GSM
16 GB
32 GB
64 GB
iPad Pro 10.5"
Wi-Fi/Cellular
iPad Pro 12.9"
Wi-Fi/Cellular
iPad Pro 9.7"
Wi-Fi/Cellular
iPhone 1st Generation
16 GB
4 GB
8 GB
iPhone 3G
16 GB
8 GB
iPhone 3GS
16 GB
32 GB
8 GB
iPhone 4
16 GB
32 GB
8 GB
iPhone 4S
16 GB
32 GB
64 GB
iPhone 5
16 GB
32 GB
64 GB
iPhone 5c
16 GB
32 GB
iPhone 5s
16 GB
32 GB
64 GB
iPhone 6
128 GB
16 GB
64 GB
iPhone 6 Plus
128 GB
16 GB
64 GB
iPhone 6s
A1633 US AT&T Locked or SIM Free
A1688 US Sprint/Verizon and Global
A1700 Mainland China
iPhone 6s Plus
A1634 US AT&T Locked or SIM Free
A1687 US Sprint/Verizon and Global
A1699 Mainland China
iPhone 7
A1660 Verizon/Sprint/China
A1778 AT&T/T-Mobile/Global
A1779 Japan
A1780 China Mobile
iPhone 7 Plus
A1661 Verizon/Sprint/China
A1784 AT&T/T-Mobile/Global
A1785 Japan
A1786 China Mobile
iPhone SE
A1662 US AT&T/T-Mobile/Verizon
A1723 US Sprint and Global
A1724 Mainland China
Toon 28 meer apparaten
Reparatieverhalen
Avatar
Mijn probleem
My Nexus 4 has had problems shutting off or halting, requiring hard reboot, or just rebooting and getting stuck in a boot loop due to temporary hardware or software issue.
Mijn oplossing
Upgraded to a Nexus 5 and used a SIM Card Eject Tool to remove the SIM.
Mijn advies
The iFixit Sim Eject tool is slightly larger than other . . .
Avatar
Mijn probleem
Drive stopped working; no eject
Mijn oplossing
Repacement
Mijn advies
Easy repair
Avatar
Mijn probleem
Both phones (iPhone 5 and Moto X) had batteries older than 2 years and required frequent charging.
Mijn oplossing
Both phones were relatively easy to repair. Your guides and uTube videos were very helpful. Also other uTube videos not from ifixit were informative as well. Be very careful to check the iPhone power s . . .
Avatar
Mijn probleem
Glass screen shattered.
Mijn oplossing
I started out trying to just replace the shattered glass screen. That turned out to be an exercise in absolute frustration and insanity. On a scale of 1-to-10 it's a 12 on near impossible. I recommend this if you want any good results in the end process. The only solid repair . . .
Avatar
Mijn probleem
Replace a dying Nexus 4 battery to extend the life of the device by at least a year.
Mijn oplossing
Great. The tools were very useful and will come in handy for other repairs.
Mijn advies
Be gentle with the case removal step. This was the trickiest part and I ended up cracking it a little bit.
Avatar
Mijn probleem
Broken back case glass
Mijn oplossing
Took longer to write this than it took to make the repair.
Mijn advies
Directions took most of the anxiety out before I began. Great experience and feeling of accomplishment.
Avatar
Mijn probleem
My teenage daughter broke her cell screen. So after a little bit of research. I found ifixit.com saw the videos and review and decided to take on the challenge.
Mijn oplossing
I simply follow the instruction and the video examples
Mijn advies
Just make sure you have all the tools recommend. You will need it, stay organized and . . .
Avatar
Mijn probleem
I fixed the home button speaker disclosure wifi antenna cellular antenna vibrator.
Mijn oplossing
Was pretty easy not to bad on time just not so steady hands Why I took awhile but got it done.
Mijn advies
No advice
Avatar
Mijn probleem
My battery on my Iphone 5 would constantly die, it would go from 100- 70% within an hour and then it would die almost instantly when it would reach 55%.
Mijn oplossing
The hardest part was taking the battery out of the phone. It is really glued in there. With alot of patience it will come out. The new battery is wo . . .
Avatar
Mijn probleem
Original phone battery needed to be recharged 3-4 times a day.
Mijn oplossing
Following the video tutorial the process for removal and replace is straightforward. 20-25 minutes to complete job.
Mijn advies
Small screws like to take flight during removal if your not careful. A large sheet of white paper as your work surface will . . .
Geef meer weer
