Probe and Pick Set
  • Probe and Pick Set / Economy / Dental Style
  • Probe and Pick Set / USA / 25 mil
  • Probe and Pick Set / Pro / Dental Style
  • Probe and Pick Set / USA / 10 mil
Probe and Pick Set
Set of 4 stainless steel probes. Double ended dental style. Not for actual dental use.
$6.99
$6.99
We zullen een bericht sturen als het product weer op voorraad is.
Mac RAM Kits
Versnel je Mac. Breid zijn geheugen uit.
Mac RAM Kits
Haal meer megabytes uit je Mac.
Productdetails
Beschrijving
Beschrijving
Great for precision poking, prying, scraping, cleaning, probing, o-rings, springs, and other small jobs. For the toolbox of any serious electronics tech, auto mechanic, or crafty person.
Reparatieverhalen
Avatar
woodytus's Story Photo #340171
woodytus's Story Photo #340173
Mijn probleem
After very successfully replacing my 2005 HP iPod Photo battery with an iFixit kit, I just picked up a few items that will help on some of the miniature work that I'm into right now.
My eyes aren't getting any younger so the Head Magnifier, Helping Hands and Inspection scope will keep the det . . .
Avatar
Mijn probleem
Battery was dying. It would not hold a charge for a day.
Mijn oplossing
Fine. After watching the video, the replacement went exactly as shown.
it does take a steady hand.
Mijn advies
Adhesive strips were impossible to put on. We used our own double back tape.
The screws are very tiny. It would help to do the work on a white . . .
Avatar
Mijn probleem
It's the line of work I do, i fix mobile, computers, laptops, tablets etc etc. To me it isn't one job, but a series of jobs.
Mijn oplossing
They always go great, I have tons of experience in doing these types of repairs, so to me the right tool is more important than any guide. The tools ifixit sells are amazing qu . . .
Avatar
Mijn probleem
My iMacs hard drive failed
Mijn oplossing
The swap went quite well except for a couple of hickups. If I had everything set up, it would have only taken about an hour.
Mijn advies
I recommend that those who write instructions make note of connector orientations when required. when I disconnected the hd temperature sensor it po . . .
Avatar
Mijn probleem
Mon Ipod classic ne tenait plus la charge qu'une quinzaine de minutes.
Mijn oplossing
En suivant la notice d'iFixit j'ai réussi à retrouver les capacités de mon appareil.
Mijn advies
Devant la compacité de l'appareil il n'est pas évident de forcer dessus. Cependant il ne faut pas hésiter pour accéder à la batterie.
Avatar
Mijn probleem
Initially I was buying these tools to perform battery swap with my bloated iPhone battery.
Mijn oplossing
Due to the iPhone power button replacement policy. I had skipped the need to do so.
My next repair will be my scrambled Nintendo 3DSXL screen.
Mijn advies
However, these tools are more than just for iPhone. I had found many . . .
Avatar
Mijn probleem
A buzzing sound from the top-left was driving me crazy. It appears to be the power supply.
Mijn oplossing
I printen out the repair manual and carefully read it before starting. Although the suction cups are not required, they make it very easy to remove the front panel. Removing the small connectors with the spudge . . .
Avatar
Mijn probleem
because my iphone battery is dropped
Mijn oplossing
The first time I tried to use to remove my iphone is difficult but finally can be removed
Mijn advies
Be patience to remove iphone 1st gen
Avatar
Mijn probleem
I had severe problem with the ear speaker and it started to develope battery discharge issues. I live in a remote area where servicing will take 2-3 weeks. And I have a terrible fixation with understanding everything I use.
Mijn oplossing
The repair when swimmingly, until I got a little over zealous with cleaning . . .
Avatar
Mijn probleem
I needed to replace the battery.
Mijn oplossing
The hardest part was freeing the case opposite the buttons.
Mijn advies
The tab holding the black antenna cover is hinged. A photo showing the way it is made would be helpful.
Geef meer weer
