Precision Screw Extractor Set
  • Precision Screw Extractor Set
US$ 19,99
US$ 19,99
We zullen een bericht sturen als het product weer op voorraad is.
Productdetails
Beschrijving
Beschrijving
Extract tough stripped screws without damaging the device.
  • Safely remove stripped screws and replace the age-old practice of coating the screw-riddled device with wax and feathers and hurling it into the sun.
  • We know how annoying stripped screws can be. Before you resort to the rotary tool or super glue, give these little guys a try.
  • Hardened bits with 4 sharp points for gripping what's left of the screwhead safely.
  • Extractor tips are double-sided and reversible:
    • 3 drivers have the same size bits on each end, and 1 driver has different sizes on each end—a total of 5 different bits.
  • Anodized machined aluminum handles with swivel tops and pocket clips.
  • Made in USA.
Notitie
This tool requires some mechanical aptitude and careful feel. If you stripped a screw while carefully using the correct type of driver the first time, it is possible you will not be successful with this tool. Screws that are cross-threaded, jammed, or glued in place will be very difficult to remove with any tool. Our Screw Extracting Pliers are easier to use, but will not grip recessed screws.
Reparatieverhalen
sjking's Story Photo #1155636
sjking's Story Photo #1155638
Mijn probleem
I wanted to add a second primary SSD to my MacBook Pro.
Mijn oplossing
The first time around it went terribly. I bought a multi driver set to remove the screws. When I got to the Airport/Bluetooth housing, I stripped the screw. I ended up ordering the precision screw extractor set to try and remove the stripped scr . . .
Thomas Kremser's Story Photo #1049162
Mijn probleem
A 1940's Buescher 400 cornet had a broken screw on the water key, that was rusted-fast.
Mijn oplossing
The repair went great. I used the Precision Screw Extractor set.
Mijn advies
The Precision Screw Extractor worked perfectly. I needed to back out the screw without ruining the threads or marring the surface or denting any of . . .
Mijn probleem
I stripped one of the tiny screws inside the DVD bay of an HP Envy laptop while trying to remove the bottom cover and it's 13 billion screws. Ultimately I was just trying to get in to unplug the speakers from the motherboard as they were generating a crazy hiss and static every time a sound was play . . .
Mijn probleem
The pentalobe screws refused to come out
Mijn oplossing
I had read somewhere that Apple may use Loctite to insert the screws. I researched on the Internet how to loosen up Loctite. The answer was to use HEAT. I heated up the screws, using my glue gun nozzle (without the glue, of course) and when the screw was hot, . . .
Mijn probleem
I decided my new Macbook Pro needed a new Solid State Drive. Since I was going to be inside the case anyway I decided to put in a Data Doubler from OWC. A Data Doubler basically is used to replace your optical drive with a hard drive or SSD. The SSD upgrade went off without a hitch. The Data Double . . .
Mijn probleem
Cracked Screen
Mijn oplossing
Isckack didnt stick because of a Tag that was already on the Iphone
Mijn advies
Buy the Nat
Mijn probleem
need to take apart a nintendo Wii
Mijn oplossing
Havent started it yet, but satisfied with my purchases
Mijn advies
read the bible =)
Geef meer weer
