Plastic Cards
  • Plastic Cards
  • Plastic Cards
  • Plastic Cards
  • 360°
360
Plastic Cards
US$ 2,99
US$ 2,99
We zullen een bericht sturen als het product weer op voorraad is.
Productdetails
Beschrijving
Beschrijving
We're all in!
  • Two credit card-size plastic opening cards.
  • These smooth cards slide between parts and help undo clips and pry devices open.
  • Can be used for spreading thermal paste and delicate scraping tasks.
  • Better and cheaper than Apple Tool # 922-7172!
Reparatieverhalen
Mijn probleem
Battery was 2 years old and was replacing my iphone 6 battery so I figured I would do my wife's as well.
Mijn oplossing
This did not go as smooth as the Iphone 6. The SE is more difficult mainly due to the location of the home button connector and how it is connected (metal shroud).
Also the iFixit Battery was a . . .
Mijn probleem
Battery was 4 years old and no apple stores within 2hrs of my place and did not want to ship my phone.
Mijn oplossing
It went great.
Mijn advies
Take it slow. Right the size of the screws on a paper and lay them next to their correct size to keep track
Mijn probleem
Battery drains fast
Mijn oplossing
Smooth. The process is not bad at all, the replacement went well and now the new battery seems great.
Mijn advies
Keep track with your screws since some of them are different in length. Be patient and careful when taking out the old battery.
Mijn probleem
My iPhone 6 was slowing down and I read the news of the problem with batteries and Apple's slowing down older phones with original batteries. I installed the new battery and the phone seems to be speedier and it shows 99% capacity.
Mijn oplossing
I ran into difficulty with the last step of connecting the new batter . . .
Mijn probleem
I was suffering from a slow iphone 6 plus with a weak battery.
Mijn oplossing
The repair was easier than I thought it would be.
Mijn advies
It's simple. Even a cave man can do it!
Mijn probleem
My Iphone6s battery was not holding it's charge
Mijn oplossing
I took my time removing the screen, don't get to aggressive. Hardware removal went fast, I'm glad I had my 2.0 magnifiers to see. Battery adhesive strips were a pain in the butt. But I took my time. Had to break out the blow dryer to heat up the cas . . .
Mijn probleem
Had my iphone6 for over 2 years, the latest iOS was giving me that dreaded "Your battery may need replaced" warning. Wouldn't keep a good charge, and sometimes would bounce between battery levels. Looked at new phone and then found this site. After seeing the instructions, tools and testimony i deci . . .
Mijn probleem
My iMac was running super slow. Every test I ran on my hardware reported no issues. However I concluded the issue must be my HDD. So, I decided to slap in an SSD.
Mijn oplossing
I have heard/read horror stories about the sealed up Macs of recent years and how they are terrible to work with. I was rather nervous to . . .
Mijn probleem
Overheating causing frequent restarts
Mijn oplossing
Super easy and quick. Just make sure to follow directions on bottles of cleaning solution and new thermal paste. Dont use too much paste!
Mijn advies
Runs cooler than when new. I would say a thermal paste upgrade is a must in MBP.
Mijn probleem
Battery discharging within 24 hours and not connecting to charger cable
Mijn oplossing
A successful repair and I was pleased with the instructions and parts supplied.
Two major challenges:
1. Getting the case open was very difficult. It took all my strength over many attempts over 2 hours to get even a sliver of a . . .
Geef meer weer
